Discussion topic: No Internet Connection
This message was authored by: Mart24
The system says my internet and WiFi are working, but yet again they are not. This is becoming a daily problem despite getting a new router! This needs sorting!
Re: No Internet Connection
@Mart24
l’m afraid you aren’t speaking to Sky Customer Services by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
