Discussion topic: No wifi
Message posted on 12 Oct 2025 06:36 PM
No wifi
Message posted on 12 Oct 2025 06:44 PM
Re: No wifi
@Riz
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
