Discussion topic: New to Sky/Issues with openereach
Message posted on 16 Jun 2024 08:39 PM
Hi,
I'm new to sky. The openreach socket had a broken off cable at my new flat. I unscrewed the cover to take it out. After taking it out I noticed that the wires behind it looks cut. So even if I plugged in my sky hub it would not connect. Is there anyway to get someone out to look at this? Do I need to contact openreach? I'm unsure of how to go from here. Due to be activated tomorrow
Message posted on 16 Jun 2024 08:43 PM
Re: New to Sky/Issues with openereach
What package/speed have you ordered?
What socket is there at the minute?
Message posted on 16 Jun 2024 08:44 PM
@cbro1 You need to contact Sky to report that the master socket is damaged. They will have to request an engineer to come out and replace
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Message posted on 16 Jun 2024 08:52 PM
Thanks. Is there a number? I've tried online but the automated advisor doesn't have to option to report this
Message posted on 17 Jun 2024 05:46 PM
I've ordered the sky superfast broadband sky hub with sky tv. At the moment it's the openreach socket with only a phone port.
