Discussion topic: New router - not all devices will connect
This message was authored by: RAR351
Installed a new router this evening. Phone and two ipads connected quickly. One ipad and central heating control won't connect. Any suggestions please?
This message was authored by: TomThumb5ive
Re: New router - not all devices will connect
@RAR351  That could be down to a few reasons!
What new router are you now using? Possibly the new white hub? So maybe drop security from wpa3 > wpa2
What router did it replace?
What CH system controller?
Otherwise any info given is just guesswork.
Tom...
Sky want us to believe in better
BELIEVE =accept that (something) is true, especially without proof.
BETTER = of a higher standard, or more suitable, pleasing, or effective than other things or people:
Sky Q & 2 mini’s
SR203 router. > Replaced with ASUS XT9’s with a TP-Link TD-W9970 modem
Sky superfast 80/20 :sort of, 63-75/15. Devolo 1200 wifi > Replaced with cat 6
Sony KDAF8 65 oled.
This message was authored by: Rich75
Having exactly the same problem with our sky max hub after we had to switch the power off yesterday. Hive would not connect sorted eventually but it still will not find our Blink Sync Module 2 now and it's driving me mad. Never experienced any issues with EE in these devices. Two smart TVs that used.to.connect on EE don't recognise sky Max Hub either. Dropped security to WPA2 but hasn't helped. Been with Sky Broadband for one month and now regretting this decision.
Avatar for RAR351
New router is Sky max, old one is Sky hub.
Connected the old one back up last night and it's great, All systems working.
Wonder if it's the lead connecting router to mains socket?
Socket has 2 ports, one is smaller ethernet type, other is usual phone connection port.
Old hub connected in ethernet hub, new one said to use phone type connector. Also, instructions said to wait til white light goes solid, after 30 minutes still not solid, but some appliances connected. Should I use the Broadband 2 connector with the max, which goes into the ether net port?
