7
This discussion topic has been answered Discussion topic: New router doesn't recognise air printer
This message was authored by: Firepuffer
Hi all,
I've just upgraded to full fibre broadband, but since its been installed I can't print wirlessly from any device other than the Mac which is hard wired to the printer.
Printer is a Canon Pixma, which previously worked fine.
Re: New router doesn't recognise air printer
@Firepuffer if youbhavecthe white Sky hub go into the My Sky app to find the hub's advanced settings and changectge WiFi security setting from WPA3-T to WPA2 as the newercsetting can stop some devices connecting.
@Firepuffer
Have you reconnected it to your new broadband router?
I am NOT a Sky Employee
Avatar for Firepuffer
Do I do that on the printer if so, no. Will have a look at setup
@Firepuffer you often need to reboot both the printer and the Mac before other devices can pick up the printer. Airprinting is great when it works and a pain when it doesn't.
tried this but still no joy.  Have tried connecting from the  printer.  It finds the network OK, but fails to connect?
Alan
OK thanks, will try this.
Thanks thats sorted it!!
