Discussion topic: New Max Hub wont activate
Message posted on 13 May 2026 08:01 AM
My hub is up and working but won't activate through MySky so I cant setup the Port Forwarding i need for my security cameras.
I als I have a booster on the way which I also believe needs the hub activated to work.
Anyone resovled this?
Message posted on 13 May 2026 10:48 AM
Re: New Max Hub wont activate
@Tormula wrote:My hub is up and working but won't activate through MySky so I cant setup the Port Forwarding i need for my security cameras.
I had the same when i first got the Sky max hub. I had to call Sky and get some broadband backend team to sort it out.
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 14 May 2026 02:10 PM
Let us know if you get your CCTV port forwarding running ok. I've had no remote access since last December. All ports are closed and Sky cannot be bothered to fix it
Message posted on 14 May 2026 03:33 PM
