Discussion topic: No WiFi?
Message posted on 14 May 2026 02:42 PM
No WiFi?
No WiFi checked & cannot see what the problem is?
Message posted on 14 May 2026 02:55 PM
Re: No WiFi?
Do you mean no broadband?
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
