6
This discussion topic has been answered Discussion topic: New Customer hub set up problems
This message was authored by: Jan150
Setting up by following instructions MySky will not work. Get to the screen where it tells you it's setting up the hub and screen goes blank and nothing happens. I'm not a complete technophobe, I usually manage, but this has me close to murder
This message was authored by: Highlinder Answer
Re: New Customer hub set up problems
@Jan150  Is it showing in the my Sky app that you broadband install has been completed?
Avatar for Jan150
Problem is resolved, thank you all
This message was authored by: EHW1
I have the same problem, what did you do?
This message was authored by: Diamond7
I also have the same problem, how did you resolve this?
@Diamond7 many of these issues resolve themselves within 24 hours however if your hub diesn't connect call Sky as they need to cirrect the issue from their end.
Did you do any action to fix this?
