Discussion topic: My wi-fi keeps disconnecting
Message posted on 19 Mar 2024 08:32 AM
My router disconnects all the time.
Message posted on 19 Mar 2024 10:36 AM
Re: My wi-fi keeps disconnecting
@Ilario Could you please post your router stats following the link below.
Message posted on 20 Mar 2024 10:40 PM
My Wi-Fi drops from time to time. Can anyone help me to sort it out. It's new router sky. Thanks
Message posted on 21 Mar 2024 12:11 PM
@Ilario It is not your Wi-Fi that is dropping out. It is your broadband that is dropping out. The next time is happens can you follow the directions below please.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
