Discussion topic: My hub keeps dropping.
Message posted on 29 Jan 2025 12:24 PM
Message posted on 29 Jan 2025 12:31 PM
Re: My hub keeps dropping.
@Swardie wrote:
Please sort issues out.
@Swardie
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
Message posted on 29 Jan 2025 04:32 PM
