Discussion topic: My broadband isn’t stable
Message posted on 01 Jan 2024 10:45 AM
Currently it's dropping out a few times a day - this problem has been since around two weeks ago. No real issues before then.
Message posted on 01 Jan 2024 02:12 PM
Re: My broadband isn’t stable
Message posted on 01 Jan 2024 03:08 PM
Your wan line did drop, but that can be for a number of various reason's can you give a little more detail,
do you see any change on the led's on the router, it looks like it auto reconnect's as your WiFi is staying
up and you are not having to power of, and finally which router and service do you have if you know.
Message posted on 01 Jan 2024 03:12 PM
It drops a few times a day and then reconnects (but this is an issue as I work from home and can be in the middle of a meeting when it happens!)
Im not sure of the whole info of the connection - it's the hub and it is through a micro filter.
Message posted on 01 Jan 2024 03:13 PM
When it drops then there is a change in the LEDs (it often goes orange and then back to green again).
Message posted on 01 Jan 2024 03:19 PM
That will be the Internet dropping the line, also on your router 3 or 4 led's standup or lay flat.
will also copy a link so you can say which you have, i would start by replacing the DSL filter, maybe
you have a spare one lying around.
Setting up your Sky hub | Sky Help | Sky.com
@Travellingkat& @Gullett125 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 01 Jan 2024 03:22 PM
I have!!! It says everything is ok. My devices have lost connection around 5-6 times already today
BT Openreach has a threshold for reporting a fault as ten drops a day or extended downtime that is a result of broadband line errors. Usually, with a broadband line like yours BT Openreach DLM system will attempt to stabilise the broadband line, unfortunately, it isn't perfect and with intermittent issues it sometimes fails and a human has to be assigned to address the issue, eg: Sky or BT Openreach engineer.
Message posted on 01 Jan 2024 03:30 PM - last edited: 01 Jan 2024 03:39 PM
We are customers like yourself trying to assist you as best we can, your working from home does not apply and a few times on your first post to more? if you wish to call SKY customer support that is also an option, but if they test and find no fault you will probablly not get an engineer visit.
Message posted on 01 Jan 2024 04:14 PM
I appreciate all the advice from everyone. It's very kind of customers to reach out and offer help - Sky should have a system where you can talk to one of their people to see if a problem can be resolved.
Message posted on 01 Jan 2024 04:20 PM
They do, but when you have an intermitant issue like you have, and you do NOT call them directlly
the will never know, If you have a landline calling 150 get's you to SKY and you have to fight the BOT.
The suggestion on the post is then down to you as the CUSTOMER which way to go.
If anyone can be off assistance we are here to help. Have a good one.
Message posted on 01 Jan 2024 04:37 PM
@Gullett125 Could you please post your router stats following the link below.
