Discussion topic: Mr Kristian
This message was authored by: Kris35
Mr Kristian
Hi am not getting a a Wi-Fi signal in my bedroom my phone's and everything keeps going off mainly off at night time even when I'm in the same room broadband it's not connecting
This message was authored by: Me134
Re: Mr Kristian
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
