Discussion topic: WiFi issues
Message posted on 15 Jun 2026 10:46 AM
WiFi issues
The WiFi keeps dropping out. I have to use my data while I'm sat 5 feet away from the hub. Thinking of changing provider as this has been an ongoing issue for a while now
Message posted on 15 Jun 2026 01:21 PM
Re: WiFi issues
@Ub40 wrote:The WiFi keeps dropping out. I have to use my data while I'm sat 5 feet away from the hub. Thinking of changing provider as this has been an ongoing issue for a while now
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
