Discussion topic: Poor coverage
Message posted on 15 Jun 2026 12:18 PM
Poor coverage
I do not have full coverage of Wi-Fi throughout my house
Message posted on 15 Jun 2026 01:19 PM
Re: Poor coverage
@Steve50094 wrote:I do not have full coverage of Wi-Fi throughout my house
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky Q with 2TB UHD box wired to the Sky Max router
Sky FTTP 500Mb to Max Hub
