6
This discussion topic has been answered Discussion topic: Missing ONT
This message was authored by: TonyFor
Missing ONT
Hi, I have had my sky equipment delivered but when setting up I have discovered that the ONT is missing. The fibre cable is there but the ONT is not. How do I get one fitted please?
Re: Missing ONT
@TonyFor
You'll need to phone Sky, who will notify Openreach (or their equivalent in RoI) that a replacement is required.
Re: Missing ONT
@TonyFor
Avatar for TonyFor
Re: Missing ONT
Thank you.
This message was authored by: Aleejai7
Re: Missing ONT
Did it work have the exact same problem did they just send u a new one
Re: Missing ONT
@Aleejai7 Does not work that way, you call sky and they will organise OR to have one installed by them, no sending in the post to you.
This message was authored by: AngrySteve
Re: Missing ONT
Where do you find the number to call as I cant find it anywhere and keep getting sent to an AI chat bot!
Re: Missing ONT
@AngrySteve You will find it here, post 4 click the link and then call us!
https://helpforum.sky.com/t5/Broadband/Moving-Home/m-p/5080372
