Discussion topic: Wifi
This message was authored by: Danielle190189
Wifi
WiFi is not working unplugged and tried to reset through sky settings but still not working
Re: Wifi
@Danielle190189
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
