This discussion topic has been answered Discussion topic: Miss Loopy17
Message posted on 30 Jun 2025 08:03 AM
No WiFi
Message posted on 30 Jun 2025 08:14 AM
Your duplicate thread has been removed as has a duplicate post on here. Even if you need an engineer it won't be today.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 30 Jun 2025 08:04 AM
Re: Miss Loopy17
No WiFi I need a engineer to attend today
Message posted on 30 Jun 2025 10:44 AM
Re: Miss Loopy17
That's just not going to happen as your agreement is for domestic broadband which carries with it a SLA of 2 working days from reporting it to Sky (if there is a fault), by posting here you're not reporting it to Sky.
If there is no fault Sky or more important, Openreach simply won't attend to sort out your internal wifi issues.
