Discussion topic: Broadband not working
This message was authored by: Petra007
Hi,
in the past couple of days my broadband has stopped working - sometimes it does work, but most of the day it doesn't. As I am working from home, this causes me serious troubles. I have restarted the wifi device several times and unplugged and reconnected everything, followed all instructions in the app how to fix issues, but nothing helped. The wifi shows green light for Power, Wifi and Internet, and the service checker website says everything is running perfectly - however, I do not have internet! I checked all my devices (laptop, mobile) it's not working. Please can you help me ASAP as I need it for work! Thank you
Re: Broadband not working
@Petra007
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
@Petra007
In addition to the above remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support if you're wfh.
