09 Jan 2025 02:12 PM
After extending my Broadband with Sky in December 2024, my minimum speed has been more than halved and my actually speed has also more than halved. I am hoping this is just a mistake and can easily be resolved and is not a way for Sky to 'save costs'.
Facts
I have the orginal email from 2023 and at least 6 years of fast broadband experience to know that my speeds 'settled' on the 40Mbps mark (after starting off in the mid 60's).
After a call to the support line, they reiterated the lower guarantee speed (frustratingly) whilst confirming I am on the highest (same named) package available to me.
Can someone please explain how this happened and what I need to do to get it resolved?
Duncan
09 Jan 2025 02:17 PM
So they told you the speed would be lower when you renewed?
09 Jan 2025 02:22 PM - last edited: 09 Jan 2025 02:38 PM
'Guaranteed' speed is calculated from Openreach line data for that particular circuit: if the connection has degraded (line conditions or cabinet crowding) then the 'guarantee' will be decreased.
ISPs don't save any money other than the difference between 80/20 and 40/10 wholesale rental.
09 Jan 2025 02:23 PM
It was done all through the automated system (ie I received and e-mail saying 'thinking of leaving us' and then I clicked through to renew). I can tell you that at no point during that process did it say my speed was reducing (in fact, it still showed that it was going to be 30+). The e-mail I subseqently received though does give an updated minimum speed (which I have obviously missed until now).
09 Jan 2025 02:28 PM
In regards to it being set by OpenReach, if I go onto a comparison site and enter my details, I am still offered broadband up to 67Mbps (as I always have done in all my previous moves between providers) - obviously I don't actually get that speed but have been stable around 40 for when FTTC first came here about 7 years ago. Neighbour, who is further away for example is also steady around 45Mbps.
09 Jan 2025 02:54 PM
Just went through the process on the BT website and they say I should be getting between 36-50 with a minimum speed of 30Mbps.
09 Jan 2025 03:31 PM - last edited: 09 Jan 2025 03:33 PM
It's perhaps worth noting that all such 'guarantees' are actually a guarantee of a small refund and early exit without penalty if that speed isn't reached.
Below that, there's the Universal Service Obligation of 10/1 Mbs (with BT Broadband being the USO provider)
All of this is based on the legacy copper network, and rendered redundant by FTTP.
09 Jan 2025 04:01 PM
What speed does the BT Wholesale Checker show for you address?
Also what router are you using, was it replaced when you renewed?
09 Jan 2025 04:10 PM
@FLC -thanks for the useful link.
VDSL Range B Impacted states I should have a High Downstream of 61.6 and a Low of 40Mbps. Currently observed is 14.99.
09 Jan 2025 04:23 PM
Then I would guess you have a fault. The problem now though is that you've accepted the new figures & Sky will almost certainly hide behind those, as you've found. Only two options I can see are one of the Superusers escalating this to Sky, who may look at it more sympathetically. Or if you're still within the cooling off period, use that to invoke a move away. A call to the "Thinking of leaving" dept or whatever it's called may elicit a better response.
The reason I asked about the router is I was supplied with the SR213 when I signed up in November. It's a piece of junk so I bought an SR203, but that only gave around half of my usual download. No idea why that is but swapping back & forth, it's 100% repeatable. That was brand new but I haven't seen any other reports, so maybe just another piece of faulty Sky hardware..
09 Jan 2025 04:34 PM
@FLC - Thanks for the advice - looks like I am still within the 31 day cooling off period so will do as you suggest tomorrow and let you know how I get on. In regards to the router, it is still the original SR203 so nothing has changed there.
