Discussion topic: Obtaining credentials to use my own router
This message was authored by: Badblood
Hi all. Looking for a little assistance. I have just taken on a Sky broadband account. I have asked if I can use my own router (it is better than Sky;s hub) and I keep being told it isn't possible. I know it is but I would need my credentials. Can anyone advise how I can get Sky to tell me? The Sky Hub has not yet arrived but are the credentials included?
I am in the UK and it will be part fibre. I have my own IT company so I can work out the options to make the connections. But Sky customer service, that everyone leeps telling me is fantastic have been absolutely useless so far.
Any help appreciated.
Re: Obtaining credentials to use my own router
@Badblood
Is this a business connection
Is your line a g.fast or vdsl line
For part fibre you need a seperate dsl modem and router or combined modem router such as the asus dsl ax82u for vdsl
In the client identifier (option 61) enter anything@skydsl|anything
And enable vlan id and enter the value 101
@Badblood
Sky uses generic rather than individual credentials, the format of which is widely available online.  What's more important is that the router supports DHCP Option 61 on the WAN connection.
Advice related to using Wireshark or MAC cloning is no longer relevant.
Avatar for Badblood
Thank you both. This is just a standard consumer line with an existing Openreach dsl line. I just assumed that the 'anything' in the credentials field was an exemplar for privacy and not verbatim, lol.
As an aside, first network I built was Novell Netware running on 10base 2 ethernet part based on a Token Ring, so I have been around a bit, so protocols and support for vlans etc in the router is meat and drink.
Again, many thanks.
