15 Oct 2024 05:34 PM
I am not getting anywhere near my package speeds(500mbps). I have speed tested it and only get 14mpbs max. The router is set up correctly and there are no visual issues.
16 Oct 2024 02:29 PM
Posted by a Superuser, not a Sky employee. Find out more@Macey4 What device are you testing on
16 Oct 2024 04:05 PM
Hi,
2 seperate iPhones both came back below 250mbps and a ps5 came back at 7mbps.
16 Oct 2024 04:10 PM
Posted by a Superuser, not a Sky employee. Find out more@Macey4 The quoted 500mbps figure is for ethernet connected devices, not WiFi. The speeds your getting with your iPhones of around 200mbps is perfectly acceptable for the service. If you have the Sky WiFi max addon Sky will only provide boosters at a speed lower than 25mbps in each room.
