Discussion topic: Loss of connection to the internet
Message posted on 18 Mar 2025 04:34 PM
Cannot connect at all. I have gone through all the check and it says it's slow in my area, but still no connection at all.
Message posted on 18 Mar 2025 04:40 PM
Re: Loss of connection to the internet
Going through the same thing.
I've ran diagnostic tests,says everything is working but it's not connecting to TV or Sky box or mobile devices.
Message posted on 18 Mar 2025 05:03 PM
Message posted on 18 Mar 2025 05:30 PM
