Discussion topic: Loss of Signal
This message was authored by Paul12961 This message was authored by: Paul12961
Loss of Signal
My Sky broadband is working fine and with the correct mbps, but if you move to the kitchen or yard, you loose the signal. We have broadband extenders, but this has not solved the problem. Any ideas?
Re: Loss of Signal
@Paul12961
Broadband extenders from Sky or 3rd party?
I am NOT a Sky Employee
Paul12961
Re: Loss of Signal
Hi,  They are third party and worked great with our old broadband.
Re: Loss of Signal
@Paul12961
Have you checked they are compatible with your new Sky hub & that you have reset them and connected them to your new hub?
Paul12961
Re: Loss of Signal
Hi, yes I have. The lights on them show they are connected and working
