2
This discussion topic has been answered Discussion topic: LOS light isn’t on
This message was authored by: Clairek1988
LOS light isn’t on
My LOS light on the open reach box isn't on, but the other three are
This message was authored by: cookiemonsteruk Answer
Re: LOS light isn’t on
@Clairek1988
You don't want los to be on as that would be a fault
What issues are you facing
@Clairek1988
Avatar for Clairek1988
Level 0 icon
That makes so much sense 🤣 my broadband went down. It's now back up and running other than not working with the apps on the tv.
