Discussion topic: Issue connecting Eufy Doorbell
Message posted on 30 May 2025 12:22 PM
I have just purcased an eufy floodlight camera and a camera doorbell. The floodlight was able to connect to the wifi no problem but the doorbell will not connect. It says it needs 2.4 GHz Wi-Fi but on my hub i'm not able to see/change anything!
Message posted on 30 May 2025 12:41 PM - last edited: 30 May 2025 12:42 PM
Re: Issue connecting Eufy Doorbell
@Hannah_Lismore What hub do you have, also see the tips link from above.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 30 May 2025 01:35 PM
I have the Sky Max Hub, the white one
Message posted on 30 May 2025 01:43 PM - last edited: 30 May 2025 01:45 PM
@Hannah_Lismore The link still applies, you just follow as per the white hub off the 2nd link on the post!
Message posted on 18 Jun 2025 10:23 AM
How does this help someone set up their video doorbell? This hasn't helped me..
Message posted on 18 Jun 2025 10:55 AM - last edited: 18 Jun 2025 10:58 AM
@Haggis0307 What hub do you have from sky! and if you check outside where you have put the doorbell do you still get a wi-fi signal on your mobile if you have one! Disable wi-fi on a band as a temporary measure to get the doorbell connected to the wireless wi-fi.
Change your Sky Max Hub WiFi settings | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 18 Jun 2025 07:00 PM
@Haggis0307 wrote:How does this help someone set up their video doorbell? This hasn't helped me..
@Haggis0307 Remember everyone responding on here is a customer like you, not Sky employees.
Perhaps being a bit more civil to people giving their time trying to help you might get you a better result!
Message posted on 17 Aug 2026 04:41 PM
I have a eufy doorbell and white max hub. I just swapped from virgin to sky and read this and other eufy connection threads with horror. However my alarm was unjustified. I connected my doorbell swiftly just like all my other devices. No messing around turning bands off. Maybe hub firmware is now updated
Message posted on 20 Aug 2026 06:01 PM
My eufy doorbell won't connect to the sky max hub anymore - it was working fine up until a few weeks ago - can't get it to connect and my Hive hub 360 won't connect either
