Discussion topic: Internet slow and drops out
Message posted on 07 Aug 2024 09:12 AM
In the last 3-4 of months our internet has gone slow and often drops out.
We didn't have this problem previously or with our previous provider BT. Also the equipment has been moved or changed either
Message posted on 07 Aug 2024 06:00 PM
Re: Internet slow and drops out
@nic5890 Do you have a black or white router from Sky and it is not clear in your post if the equipment is now in a different place than it was before.
Message posted on 07 Aug 2024 06:07 PM
The router is black and has not been moved the entire time we've had it.
Message posted on 07 Aug 2024 06:08 PM
@nic5890 Could you please post your router stats following the link below.
Message posted on 07 Aug 2024 06:30 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 166993455 603671234 0 1056 1402 845:30:09 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 1583897 0 10440 0 845:30:19 WLAN (5 GHz) Up 1512989488 448059447 0 0 0 845:30:17
Message posted on 07 Aug 2024 09:41 PM
Connection Speed download 159900 kbps upload 30000 kbps
Message posted on 07 Aug 2024 09:54 PM
@nic5890 We need the all of the router stats and just now the speed you are getting to the router.
Message posted on 08 Aug 2024 12:10 PM
@nic5890 Are you seeing the slow down on all devices that you have connected to the router? Can see no drops in the connection and with 35 day uptime have you tried to re-boot the router to see if this makes any difference.
How many devices are connected to the Wi-Fi and are any used to do heavy downloading?
