06 Sep 2024 01:22 AM
I have tested through MySky app which says everything looks normal but the internet light on the hub is off and I can't connect to the WiFi with any of my devices.
could you please help?
06 Sep 2024 01:48 AM
Having the same problem here.
06 Sep 2024 06:59 AM
I'm having the same issue
06 Sep 2024 08:57 AM
Posted by a Superuser, not a Sky employee. Find out more@alessiomont& @BenedictG The time you posted would be the time for normal maintence on the network
@Matt22 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
06 Sep 2024 09:11 AM
06 Sep 2024 09:21 AM
Same here, no internet for at least 5 hours so far. Checker comes back saying everything is fine but can't connect to internet in reality.
06 Sep 2024 09:23 AM
Posted by a Superuser, not a Sky employee. Find out more@rhidee The service checker shows historical data. Have you clicked on te broadband button on the service checker to run a broadband test?
06 Sep 2024 10:50 AM
Yes, ran full test as well as turning on and off and resetting. It says service is fine but 0 devices connected, which isn't true.
06 Sep 2024 10:52 AM
Posted by a Superuser, not a Sky employee. Find out more@rhidee Where are you in the country, as we are seeing reports from West Sussex
06 Sep 2024 12:33 PM
East Sussex!
06 Sep 2024 12:50 PM
Posted by a Superuser, not a Sky employee. Find out more@rhideeCan you run the service checker again to see if it is showing the outage please.
06 Sep 2024 12:58 PM
I'm in West Sussex and mine has just started playing up, the light goes off, I do everything that needs to be done and the checker says there's not a problem when there clearly is.
06 Sep 2024 01:01 PM
Posted by a Superuser, not a Sky employee. Find out more@BigBertha69 the service checker shows historical data from its last check. If you need an updated broadband test click on broadband in the service checker.
06 Sep 2024 01:08 PM
I did, I've done every conceivable thing and yet it's still telling me it works when it's not.
06 Sep 2024 01:23 PM
Also East Sussex and been without internet since 6am this morning! Next available appointment for sky to resolve issues is 17/9!! Complete joke!!
