Discussion topic: Internet constantly dropping out
This message was authored by: G8merD4d
Hi, My internet connection is dropping out multiple times daily, every time I do the sky app check it says there is no issues. This has been happening for months now.
Re: Internet constantly dropping out
@G8merD4d  Do you have a black or white router?
Avatar for G8merD4d
I have a black router.
@G8merD4d Could you please post your router stats following the link below.
Avatar for G8merD4d
This message was authored by: Mandy2503
My Internet fails multiple times a day, I do a connection test amd it says everything is fine but it's not. I'm so fed up of the treatment I've received I've now left sky. You can get much better deals and get to speak to a real person which helps a lot.
@G8merD4dAre you restarting the router with the amont of up time being less than an hour or is the router doing this itself?
Avatar for G8merD4d
I had to reset the router to be able to log in.
It's usually the mornings when it's worse but it will just randomly drop out.
