Discussion topic: No WiFi in my iPhone other phones are fine just for Apple is there any issue ?
This message was authored by: Pati1
Re: No WiFi in my iPhone other phones are fine just for Apple is there any issue ?
@Pati1 there is no reason why an iPhone wont connectvto a Sky Hub's wifi however they can be tricky to connect. I would suggest telling your phone to forget the Sky connection then fully restart the phone so it does a reboot. You msy need ti check the Apple support pages for how to do that as it varies by model but typically you hold down one of the volume buttons with the side button until the power off slide appears.
Then restart the phone and once fully rebooted try to connect again it should work. Once one ios device is connected if you bring another ios device close to it and try to connect to the Sky hub the orginal devicecshould offer to share the password.
