Discussion topic: Intermittent WiFi connection for 1 week
Message posted on 27 Mar 2024 07:49 PM
Message posted on 27 Mar 2024 08:07 PM
Re: Intermittent WiFi connection for 1 week
@Richard105 Could you please post your router stats following the link below.
Message posted on 27 Mar 2024 08:16 PM
I'm not able to get past the request for user name and password. I've tried admin and sky, and admin and my router password
Message posted on 27 Mar 2024 08:18 PM
@Richard105 Which router do you have from the link below.
Message posted on 27 Mar 2024 08:20 PM
@Highlinder I'm not able to get past the request for a username and password. I've tried admin and sky, and also asmin and my router password, but neither worked
Message posted on 27 Mar 2024 08:22 PM
@Richard105 I did ask in my previous post what router you have from Sky. Thus I can tell you the combo you need to get in.
Message posted on 27 Mar 2024 08:23 PM
@Highlinder the black hub
Message posted on 27 Mar 2024 08:24 PM
@Highlinder the black broadband hub
Message posted on 27 Mar 2024 08:25 PM
@Richard105If you are talking about the Sky broadband hub. then the username is " admin " without the quotes and your Wi-Fi password unless you have changed the password to login to the router.
Message posted on 27 Mar 2024 08:30 PM
@Highlinder tried both, but it's not accepting either, so it must have been changed
Message posted on 27 Mar 2024 10:00 PM
@Richard105 If that is not working try and hold the reset button in for 30 seconds and see if it works then.
Message posted on 28 Mar 2024 11:22 AM
If you are trying to do it with an Apple device then try a non apple device or at least not Safari.
Message posted on 29 Mar 2024 11:14 AM
@Highlinder thanks the 30 second reset worked with the password on the back of the router. Here is the text copied and pasted from the maintenance tab....
Message posted on 29 Mar 2024 01:17 PM
@Richard105 See at the bottom of the maintence tab you will see show statistics you need to click on that please and you will then see what we need.
