20
This discussion topic has been answered Discussion topic: Installation Query - existing ONT.....
This message was authored by: Cannon
Hi
My install takes place this week for fibre broadband. My query relates to my existing connections. I was with TalkTalk, so have a cityfibre installed ONT.
I had to choose supplier not listed on my order as i am disconnected, so
My question is whether this will be a new install with drilling. or if my existing cityfibre will be used, as you partner with them.
Thanks for any help.
This message was authored by: cookiemonsteruk Answer
Re: Installation Query - existing ONT.....
@JimM1
Good thats cityfibre for sure 👍
@Cannon
What speed did sky say you would get?
Avatar for Cannon
Hi
It is the fibre 150 I ordered, I think.
@Cannon
Sounds like you will get a new install .  What was the upload ?
Could you enter your full address below and post the table and notes after removing your address from the image
@Cannon
The main way to deduce whether its openreach or city fibre is cityfibre would give you 150 Mbps download and 150 Mbps upload symmetric speeds while openreach do assymetric 150 Mbps download  and around 30 upload
Avatar for Cannon
Hi
Can't really post it on this from my phone. So some data... FTTP Upstream on Demand 1000, Downstream 220
@Cannon
Fttp on demand is different .  You'd be looking for wbc fttp for domestic full fibre..  when you subscribed what actual upload were you quoted
Avatar for Cannon
Hi
Sorry, not really technical. Not sure what you mean by quoted, just chose the 150 option as it came up as available for me to get.
@Cannon
You should have been given an upload speed as well
Avatar for Cannon
  • Yeah it probably did, I just did not note it.
@Cannon All the information up/down min/max expected etc will be detailed in your e-mail from sky, if you have 150/150Mb/s then CF is the one, OR would be 150/30Mb/s!
Avatar for Cannon
Hi
I have only had a confirmation of the install date so far. Signed up for an account and no data there either yet.
Thanks for your help guys.
@Cannon
You could try the sky.com website without logging in as if you were a new customer and check the correspondind upload speed to what you have requested
Avatar for Cannon
Thanks, I did that and got 145-152 download and 126-151 upload.
@JimM1
