Discussion topic: Hub connecter
This message was authored by: Louise199
Message posted on 15 Mar 2024 08:17 PM
Hub connecter
Hello our hub the connection to the box in the wall and the hub snapped
Message posted on 15 Mar 2024 08:58 PM
Re: Hub connecter
@Louise199 If you have full fibre to an ONT then the lead is a cat5e ethernet cable.
If the connection is to an OR master socket then it is an RJ11 connection.
Ethernet has 8 pins all connected, RJ11 has 6 pins only 3 and 4 connected 2 wires only.
