Discussion topic: How to disable MAP-T
Message posted on 19 Jun 2025 09:02 AM
I need MAP-T disabled on my broadband as I can't connect to my works VPN. How do I go about doing this?
Message posted on 19 Jun 2025 09:08 AM
Re: How to disable MAP-T
@ShannenD The link at the top off the page explains it all and what is required for you to do, it's one off the pinned post's.
Message posted on 19 Jun 2025 09:53 AM
@ShannenD As oper @JimM1 reply please see this post https://helpforum.sky.com/t5/Broadband/Having-problems-with-a-3rd-party-VPN-and-have-a-Hub-6/td-p/48...
Message posted on 19 Jun 2025 10:52 AM
I need to disable MAP-T
Hi, I need to disable MAP-T. My VPN through work cannot detect.
Please can this be done by a sky staff employee. The customer advisors didn't have a clue.
Message posted on 19 Jun 2025 10:55 AM
Re: I need to disable MAP-T
@ShannenDrum If that was your other post earlier then you where answered on that!
Message posted on 19 Jun 2025 11:44 AM
Seems you've created two log in user names, is that correct?
Message posted on 19 Jun 2025 01:18 PM
@ShannenDrum Please see my reply directly above your post. If you are the same poster as the original OP you need to follow the steps provided previously also.
