Discussion topic: No broadband or tv
Message posted on 19 Jun 2025 01:01 PM
No broadband or tv
No broadband or tv since Tuesday
Message posted on 19 Jun 2025 01:07 PM
Re: No broadband or tv
@NOBBORTV186
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 19 Jun 2025 01:19 PM
@NOBBORTV186 If you have Sy Stream or Glass and your broadband is down then clearly Glass/Stream won't work either.
