Discussion topic: How do I get WiFi max hub
This message was authored by: BAKER126
I currently have the highest broadband they offer ultrafast £43 month but I have the old router black. Sr203 I believe. My contract ends 03/2025.
Should I be getting the max hub as standard or is it extra?
Re: How do I get WiFi max hub
@BAKER126
The white Max Hub is now the default hardware for all new FTTP, but prior to that it was an additional cost add-on.
The be honest, unless you really need Parental Controls there are numerous posts in this forum which suggest the Sky Broadband Hub may still be preferable.
Avatar for BAKER126
Level 5 icon
Thanks for reply..
To be honest my child is coming of age where protection will be useful.
Should I wait till march or am I allowed to ask for a white router now and enter a new contract I assume?
Many thanks
@BAKER126
Parental Controls are an added cost extra (with the WiFi Max service) rather than just bundled with the Max Hub hardware.  I suspect Sky would be very happy to sign you up, although they won't currently do so if the address has multiple Sky Q television boxes.
