09 Jul 2024 03:12 PM
Hi as the above subject. Today i was streaming a tv show on my Amazon Fire Stick and the programme keeps stopping making me restart the programme then it stops again. Im using a Sky Broadband Hub which ive also held down the reset button for over a minute and after doing this im still having the same problem with the tv programme stopping. I have FTTP and getting a download speed of 148Mbp/s please can someone help me? I've also gone onto my Sky app and done a broadband and WiFi test on there and it's saying there's no issues...I'm completely stumped help me please someone? Thank you.
Marc.
09 Jul 2024 03:29 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @MWW73 Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
09 Jul 2024 03:41 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 2471046 3566268 0 722 245 00:53:22 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 6384 845 0 837 0 00:53:27 WLAN (5 GHz) Up 6852892 2413121 0 0 41141 00:53:26
Hi hope this is exactly what you meant and all the information is there too see as I copy and pasted this on my iPhone
Does anything look untoward to you please?
thank you.
09 Jul 2024 03:43 PM
Hi when i went to post my previous message with my connection stays its said something about not being "HTMl" compatible on Skys website so it looks like what ive posted is not much help or is it please?
Thank you
09 Jul 2024 03:45 PM
Posted by a Superuser, not a Sky employee. Find out moreIts usually easier to post an screenshot as an image rather than copying & pasting them
09 Jul 2024 03:46 PM
Hi hope this works sorry I'm all new too this and thank you very much
09 Jul 2024 04:02 PM
Your stats show no connection drops in the 1hr your hub has been up. The problem is they get reset when you reboot the hub so it would be ideal to see the stats after notice the issue occurring but before you reboot the hub.
Is the firestick the only device you are having streaming issues with? Have you tried a different device?
09 Jul 2024 04:10 PM
Hi@jamesn123
Thank you for that ok I'll not reboot or reset my router now and see how it goes. However since rebooting the router the Amazon Fire Stick has paused a programme I'm streaming a few times which is weird why it's not showing in the stats? Everything is WiFi as the master socket is in the bedroom.
I've also had problems with watching Amazon Prime on my Sky Q box same thing basically streaming a show and it'll buffer eventually coming up with and connection message and the wife was saying she was on the PlayStation 5 last night and it was lagging on Call of Duty 3 Modern Warfare playing Zombies online aswell.
09 Jul 2024 04:19 PM
Posted by a Superuser, not a Sky employee. Find out moreYou may want to look at using direct ethernet or powerline adapters for devices like a PS5 as it would result in a better experience.
I would also recommend you go through Sky's WiFi troubleshooting to see if any of the suggestions improve your situation.
09 Jul 2024 05:10 PM
Hi@jamesn123
Thank you for your guidance and help with this issue. I've thought about Ethernet lead to the PlayStation 5, however it's such a long way from the other room where the master socket is so maybe I'll give the power line adapters a go..it's ironic really because in the kitchen I've got a Sky WiFi booster but maybe I need too move that between the bedroom and living room ie the hall. The problem with that is there's no electrical sockets in the hall though.
I tried those steps you recommended on Skys WiFi and everything seems to be ok there so as I suspected it's an intermittent WiFi issue.
The wife has been on the PlayStation 5 since she come home from work and there's no lagging.
This is how it goes it could be l like this for like two or three weeks then we have issues.
Thank you again for all your help and advice and if I have anymore issues with streaming issues I'll send you my Network Stats again before I reboot the router.
Thanks again James
