Discussion topic: Extremely slow wifi but speed tests say its fine. Long term issue
Message posted on 08 Jul 2024 12:11 PM
I have been expereincing extremely slow wifi for over 12 months now. My speed tests say its fine, as does sky. Its so slow I cannot connect to teams meetings on my laptop. Working from home has become impossible. I have screenshot my router diagnostics below:
Message posted on 08 Jul 2024 12:15 PM
Re: Extremely slow wifi but speed tests say its fine. Long term issue
@Etimms89 What you have posted the community can't use, please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Message posted on 08 Jul 2024 12:33 PM
Hi, thanks for responding.
Hopefully the below works this time?
Message posted on 08 Jul 2024 12:35 PM
@Etimms89 You've posted the same image which isn't your router stats, have you followed the steps to the very end as per the link posted?
Message posted on 08 Jul 2024 01:06 PM
I think ive got it now, the prompts are a bit different for me, see below:
Message posted on 09 Jul 2024 04:15 PM
For starters give your router a reboot as its been up for 2 months.
I notice you are on ADSL broadband which is becoming quite outdated and certainly is not appropriate to be WFH on. Is there no Fibre available to you?
Message posted on 09 Jul 2024 04:22 PM
@Re: Extremely slow wifi but speed tests say its fine. Long term issue
Message posted on 09 Jul 2024 04:28 PM
Re: @Re: Extremely slow wifi but speed tests say its fine. Long term issue
In that case you may want to consider using ethernet to WFH on as it'll make the most of your connection
Message posted on 09 Jul 2024 04:37 PM
Could you enter your full address below and post the table after removing your address from the image
Message posted on 09 Jul 2024 04:48 PM
Message posted on 09 Jul 2024 04:50 PM
Hi @jamesn123,
I will try my ethernet. If this doesnt work and neither does the reboot - do you think there is any point in trying a different modem?
Message posted on 09 Jul 2024 04:57 PM
Are you in a rural location . At the minute you are on the fastest connection you can get . I am afraid you would would have to try and ethernet as many devices as you can
Message posted on 09 Jul 2024 05:16 PM
A different router could improve the WiFi experience slightly but not drastically.
