Discussion topic: Full Fibre. Is it worth the upgrade?
Message posted on 30 Jul 2024 05:06 PM
Hi all,
We are currently having fibre fitted in my road. I spoke to the guys installing and theve said it will be a while till Open Reach verify and check everything is ok. So in the meantime i thought i would ask. Is it worth it? Any pitfalls with Sky Full Fibre? Ive had no issue with their FTC broadband. Any insights would be very much appreciated. Many thanks.
Message posted on 30 Jul 2024 05:09 PM
Re: Full Fibre. Is it worth the upgrade?
@Jasper2344 You might actually find it cheaper to move on to a faster speed as it is in the best interest of ISPs to get everyone on to FTTP and off the copper network where possible.
Message posted on 30 Jul 2024 05:12 PM
Thanks Highlinder i did look at the prices and they certiainly are better that what i am paying now. Hopefully Open Reach sort the commisioning out soon then i can contact sky and see about an upgrade.
Message posted on 30 Jul 2024 05:14 PM
@Jasper2344Going by what normally happens that Sky might be a bit behind the leead to let you upgrade when you are told it is available to you because of updating their database.
Message posted on 30 Jul 2024 05:56 PM
@HighlinderThanks i will bear that in mind and just keep trying once Open Reach have been. The install engineer said i would soon know as there will be loads of vans in my road 😂😂
Message posted on 31 Jul 2024 06:37 AM
When my street was upgraded to full fibre it was close to three month from the cabling being done until I could place an order with anyone other than bt
tge good thing about already having a working service is you have something while you try and patiently wait for the records to be updated by openreach
Message posted on 31 Jul 2024 06:43 AM
@Jasper2344 Sky are not always behind the other ISPs as in my case Openreach agreed to accept orders a only a couple of days before I called Sky to upgrade.
Full fibre delivers the speed you buy unlike FTTC where line length and cindition limit what speed you sctually get and unlike copper fibre is immune from interference so is far more reliable.
