08 Jul 2024 03:00 PM
Hi All
Can you rename device's found on the attached device tab?
08 Jul 2024 03:20 PM
Posted by a Superuser, not a Sky employee. Find out more@michaelseal1 Normally it is the devices themselves that broadcast their make and model.
08 Jul 2024 06:46 PM
Thanks, On previous routers, i have been able to name the devices, as not all state who they are?
Like i use power lines, so i could name a particular one depending on where in the property it was .
This set up doesn't allow that?
Sam
09 Jul 2024 04:17 PM
Posted by a Superuser, not a Sky employee. Find out moreYou cant rename the devices directly on Sky hubs. It may be possible to do it on the Sky Max hub via the app control.
09 Jul 2024 05:09 PM
Thanks James, not sure if we have the the max unit or not, will ask, we have only just signed up.
09 Jul 2024 05:10 PM - last edited: 09 Jul 2024 05:10 PM
The Max Hub is the white one.
09 Jul 2024 05:26 PM
Ahh Thanks @TimmyBGood we have the Broadband hub.
Is the Broadband boost worth having or should I ask to be up graded for the Max hub?
Older solid wall property, we used to have an wifi extender with BT/EE
