Discussion topic: Engineer fixed a fault but sync speed same as before
Message posted on 30 May 2025 09:47 AM
Sky app told me the speed was too slow and had an engineer booked. they did all the work outside then text to say its finished but the hub is still syncing at the lower speed according to the maintenance hub page. The app thinks its above the minimum now and said that it can get faster again in the next 7 days is that possible with a low sync speed or does that mean the engineer didn't reset DLM? thanks.
Message posted on 30 May 2025 10:09 AM
Re: Engineer fixed a fault but sync speed same as before
@Stealth_ Did your router re-start at any point during this time? What colour of router do you have from Sky, black or white?
Message posted on 30 May 2025 01:15 PM
its the black one and i when i saw the speed was still slow i unplugged it all and replugged it as per the app.
Message posted on 30 May 2025 01:18 PM
@Stealth_ When was the repair work carried out, it takes 24 hours to show on the app and also for the hub to regain and go back up in speed.
Message posted on 30 May 2025 01:25 PM
thanks. it was only just this morning, do you know if me restarting it a few times today will have impacted DLM i don't know much about it other than its better not to touch anything until it finishes, i guess over the next few days it will reset and then the 14 days starts again? thanks alot for your help
Message posted on 30 May 2025 01:31 PM - last edited: 30 May 2025 01:39 PM
@Stealth_ Are you on a copper fttc connection your hub would be plugged into a OR Master phone socket?
Some reading for you, just keep away from reseting your hub, continuing to do so you may end up getting really slammed down in speed.
Message posted on 30 May 2025 10:59 PM
yes, thats right about the fttc thanks for the link about DLM i had only heard of it recently but only know a bit from reading random posts and that seems to have everything in one place
Message posted on 30 May 2025 11:09 PM
@Stealth_ Not every engineer is allowed to do a DLM reset on a system, if they do then sky as normal kicks back up to it's preset max speed about 24hours or so later, and dlm starts working over the 10 day period adjusting and fine tuning till it get's its best conditions, a few off/on's with the switch on the hub and you are wasting all that good effort....
Message posted on 30 May 2025 11:39 PM
@Stealth_ When you unplug the router and restart it all the evidence is lost. If it happens again follow the directions in the link below and post your router stats before re-starting again or if possible leave it as is.
Could you please post your router stats following the link below.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-read-your-Sky-Hub-statistics/ba-p/3645346#
Message posted on 31 May 2025 01:57 PM
i am leaving it on again from now on its only because the app told me to unplug everything. my downstream noise margin yesterday was 24.1 and the sync speed 4399 or something. today its like this..
I have a hunch that even though the sync speed dropped more that its one of gets worse before it gets better things because those noise margins don't look right when people talk about 3 and 6 lol
Message posted on 31 May 2025 02:04 PM
@Stealth_ Your line attn figures are super, but your noise is in the toilet, with those figures i would expect you to be up at high 70's Mb/s download speed's. Only YOU know what you have and past speed's we have NO idea!
Message posted on 01 Jun 2025 01:27 AM
i don't know what the best course of action is. i can cancel my contract but not sure if that is best. openreach fixed a fault outside without entering my property i am trying to be patient and hope it gets better but even half of the minimum guaranteed speed its still randomly disconnecting and the noise margin is getting worse. i want to understand what is normal because it was at 75ish mb/s and now it can't stay stable at 40 mb/s after a fault was supposedly fixed
Message posted on 01 Jun 2025 08:28 AM - last edited: 01 Jun 2025 08:30 AM
@Stealth_ Have no idea what connection that you have from the Hub to the OR Master socket, the norm for years has been and take a look at the linked posting picture. Could be you have a bad master socket but it is very unusual for them to go bad. Do you have any internal phone extensions, and if you have a landline where does it plug in.
Re: Sky hub setup but don’t have a main phone sock... | Sky Community
Message posted on 01 Jun 2025 11:08 AM
there are 2 internal extensions but i don't use a landline phone though just plug into the master socket, i think it could be that because the plastic part where you squeeze to unplug sits flush when its in making it very difficult to unplug so probably someone damaged it before because i have never seen that, today on the stats page the noise margins are fluctuating too basically at random
Message posted on 01 Jun 2025 11:43 AM
the app let me book an engineer again now, i guess that because there was also a fault outside they fixed something and thought they didn't need to do anything else, thanks for everyones help
