Discussion topic: Connectivity Problems
Message posted on 29 Aug 2024 02:54 PM
My Sky Broadband was connected on 29.08.24 although downstairs is find, the signal on the first and loft rooms are weak. I am having connectivity problems when l am using my Chromebook to work. Please can you sort it out
Message posted on 29 Aug 2024 03:16 PM
Re: Connectivity Problems
@Denie68 Does your broadband package include broadband boost of broadband max in it?
Message posted on 31 Aug 2024 05:56 AM
Sky is sending a booster, hence l am hoping this will sort out the problem, Thank you for responding
Message posted on 31 Aug 2024 08:08 AM
@Denie68 Glad to see that you got it sorted out with getting the booster.
