Discussion topic: How to connect conversion kit 3 to my router
This message was authored by: Pete43
How do I connect my conversion kit 3 to my router
Re: How to connect conversion kit 3 to my router
@Pete43
The 'conversion kit' ethernet cable goes between the ethernet port on an ONT and the WAN ethernet port (#4) on a Sky Broadband Hub or Max Hub.
It actually works with a Q Hub too, but those don't support Sky Talk Internet Calls.
Avatar for Pete43
Can I plug the connect 3kit straight into my current phone line
@Pete43  As @TimmyBGood  the conversion kit is a Ethernet cable, it can't be used on a phone line master socket, are you waiting for a FTTP install to take place?  If so you will get an ONT which is the way you connect your hub to the ONT using said cable.
