Discussion topic: Connection issues & address conformation
Message posted on 18 Dec 2025 01:14 PM
Message posted on 18 Dec 2025 01:18 PM
Re: Connection issues & address conformation
@LucyEH You will need to call Sky to confirm all of this as this is a customer helps customer community.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
