Discussion topic: Poor signal when not in room with hub
This message was authored by: -TAJ
Message posted on 18 Dec 2025 12:53 PM
I need to speak to somebody about getting signal boosters through the house. The poor signal is causing problems with my heating controls.
no matter what number I try or what I ask the virtual assistant I don't seem to be able to get any help.
Find out more
Message posted on 18 Dec 2025 01:20 PM
Re: Poor signal when not in room with hub
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
