Discussion topic: Broadband down - York
This message was authored by: Mikem4
My broadband router is showing green. Tests are saying everything is connectedn on the router. City fibre box is showing green but nothing will connect to the router, even via ethernet cable. I have tried restarting and reconnecting everything several times but nothing is working.
Re: Broadband down - York
@Mikem4
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
