9
This discussion topic has been answered Discussion topic: Connection drops
This message was authored by: aditya05
Connection drops
My Broadband connection is keep on driving since last 2 days , Health check in sky app says all looks good, but router is blinking with orange/red lights. Could you please help me with this it's impacting my office work.
Avatar for aditya05
This message was authored by: aditya05 Answer
Re: Connection drops
Hi mate,
Thanks for your help, l have contacted sky customer care they said some line issue and arranged an Engineer visit.
@aditya05  Can you follow the latter directions in the information below after running the service checker.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Avatar for aditya05
Hi , Thanks for your reply.
Sadly all your steps shows connection is good and no issues with hub . Not sure what is wrong connection goes off for every few minutes and it's connecting back automatically after 5 minutes.
@aditya05  Did you run the test while the connection was up or was it down?
Avatar for aditya05
When it is up l have tested , when it is down it's not at all finishing the test just hanging on the web page
@aditya05  Are you using mobile data when trying to complete the test?
Avatar for aditya05
Yes l think , when WiFi goes it's connected to mobile data. Do you think test is not working because of that ? May l know the steps how to test it when wifi goes off pls ?
@aditya05  Follow the directions in post 3 of this thread to do the tests.
Avatar for aditya05
Hi mate,
This message was authored by: Adele721
Please can you check the line
