12
This discussion topic has been answered Discussion topic: Cannot connect hp envy 4500 printer
This message was authored by: Joe905
I have just got the new sky wifi max white router  but can no longer connect my hp envy 4500 pribter. l didn't have this problem with my old sky router black. I have tried everything I can think of. Help 🙏
Re: Cannot connect hp envy 4500 printer
@Joe905
Have you moved the wireless security from WPA3 to WPA2-PSK?
@Joe905
Avatar for Joe905
Take a bow sir, you are a "GENIUS" 🥸🧐😀
@Joe905
No problem.  For reference, devices of that vintage (the HP model is a decade old) cannot really be expected to handle WPA 3 (or WPA3-T) wireless encryption, which is a bit unfortunate as that's what the Max Hub uses by default.
This message was authored by: Greebothecat
I had the same issue.
Print off a report from the printer. this will give you the printer MAC address.
Enter this MAC address manually in the SKY max hub.
Connection - WIFI - Add device manually.
Then connect to network from printer.
This message was authored by: PollyH57
I'm having this issue right now but have no idea how to access the SKY Max Hub.
Please can you advise?
Thank you 🙏
How do you do this please? I'm having the same issue....
@PollyH57
Max Hub administration is through the My Sky app.
https://www.sky.com/help/articles/change-wifi-max-hub-settings
Thank you so much. Will give that a go!
Access the sky max router in your browser by typing the address 192.168.0.1
Accessing your Sky router settings page 192.168.0.1
This message was authored by: Andrew6666
ye I have the same issue, I just got sky max router and cannot connect my HP envy 4500, I'm lost
@Andrew6666 follow the advice above. However if you can link the printer up to a laptop by a USB cable and update its firmware and you should find it can get the log in from the laptop once its done that unplug it.
This message was authored by: Graeme63
Brilliant. Fixed my issue too. Thanks so much
