Discussion topic: Buffering speed issues
This message was authored by: Stephen106
Message posted on ā04 Jul 2024 09:45 PM
Help, feel like cancelling all together ! Using puck to try and stream TV , working ok with netflix, sky Atlantic , YouTube, but when I try to watch live channels BBC, ITV channel 5 etc it will work for a while then buffer or go pixelated š„“ connected using WiFi to start with then moved to ethernet . Was getting speeds between 40-60mbs , tried moving the puck away from all electrical devices no difference. Now today just tried and all channels won't play properly , did a speed check through netflix and it was average out at 10mbs and WiFi fi 15mbs š¤š¤š¤ not good! Any advice?? Otherwise I will will be going back to Virgin where I never had any issues.
Find out more
Message posted on ā04 Jul 2024 11:08 PM
Re: Buffering speed issues
@Stephen106 Could you please post your router stats following the link below.
