Discussion topic: Broken sky max hub power cable
This message was authored by: Laurakelly
Is there anywhere u can buy a sky max hub power cable mines has snapped so won't work ?
This message was authored by: Doc5907
Re: Broken sky max hub power cable
@Laurakelly
I wouldn't use a 'third-party' power supply so you would need to call Sky to get a new one sent out.
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: FLC
The SR213 uses a USB-C PSU so you should be able to use another USB-C charger to power it, as long as the replacement has the same or greater current/wattage rating.
If you want an original before Monday at the very earliest, you could search your local Facebook Marketplace or Ebay for a complete router. The router's are actually Sky's property & shouldn't be for sale, but they are.
This message was authored by: whippet85
Call SKY? Lol, tried so hard to do this, virtually impossible to speak to a human!
Depends when you call but normally you can getvthrough to an agent in a few minutes but the bot can beca pain either dontvtalk to it or refuse offers of texts etc.. If you just need  to power a Sky Max hub it is correct they can be safely powered via the USB C connectiion.
