Discussion topic: No wifi to phone
This message was authored by: Perplehair
No wifi to phone
Not connected to WiFi. Keep getting message that it is disconnected. What is happening?
Re: No wifi to phone
@Perplehair if other drvices are connecting normally I would cgeck the network settings on the phone. If those are OK then condider if the loss of connection maybecdown to where you are in your home as areas with poor WiFi signal are quite a common issue.
